跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
How to clean MacBook Pro from Coca Cola
I dropped Coca Cola on the keyboard. The computer is still working but trackpad and keyboard keys are stuck and very hard to push.
How can I fix/clean it?
It’s a better solution to buy a new top case like this one?
MacBook Pro 15" Retina (Late 2013-Mid 2014) Upper Case Assembly
Replace an upper case assembly compatible with the MacBook Pro 15 inch Retina Late 2013 to Mid 2014 model A1398. Part #661-8311.图片
产品
$71.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Don’t trust the “it’s still working”, don’t use it until you have checked internal conditions, don’t plug in magsafe and disconnect battery from the logic board. Use these guides to remove and clean logic board and I/O board and to properly take care of the spill. It is quite likely you will need to replace the upper case, there’s no real way to clean it without replacing KB. If you can find someone who will be able to take care of the keyboard only replacement that might save you some money.
MacBook Pro 15" Retina Display Late 2013 Logic Board Replacement
MacBook water damage - The definitive guide
这个答案有帮助吗?
得分 4
3条评论:
Hi,
I'm already using the Macbook for weeks now. The only problem that I have (so far) is with the keyboard keys. Supposing I will open it to clean, what kind of liquid (alcohol ?) should I use to remove the sugar?
Thanks.
完成的
@slmnbj I use >90% Isopropyl Alcohol for cleaning up liquid damaged computers. Should work like a charm for you,
完成的
@ajcooke01 wrong arrow, it should read >90% ;) @slmnbj Weeks is about the life span a liquid damaged board lasts if it has been damaged, in the best of cases. But you might have been lucky and coke didn't reach it at all. I cannot know, but I wouldn't take the risk considering the machine value.
完成的
添加一条评论
添加你的答案
Salmen Bejaoui 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 564
