跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
425 个问题 查看全部
Why is my whirlpool cabrio washer leaking water on floor
Why does my whirlpool Cabrio washer leak water on the floor during first fill
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
12条评论
Mine doesnt leak on outside when washer is off you can see slow drip to inside of tub if you have any cloth in washer they will be soaked by the morning
完成的
Similar problem I believe mine is leaking from the drain hole, the drain pump is working properly, wondering if i could just replace the rubber seal? Thanks
完成的
I notice a puddle of water in the floor around my washer not until 1-2 days after I wash. None during a wash
完成的
It is happening while the washing machine is for me. Any ideas?
完成的
My cabrio leaks water at the bottom of the washer to the back of it. Depending on the load it could be a little water sometimes quite a bit--enough to run to the basement drain right by washer. Leaks when the washer is filling initially & during the wash when it is time to fill up to rinse the load. Any suggestions on what to try to fix this problem would be greatly appreciated. Thanks!!!
Tom
完成的
显示更多的7条评论
添加一条评论
9个答案
最有帮助的答案
Most Frequent Causes for Washer leaking water
Cause 1
Drain Pump
The drain pump pumps water out the drain hose. If the drain pump is cracked or damaged, or if the bearings are worn out, the drain pump may leak water. The drain pump is not repairable—if the pump is leaking water, replace it.
Cause 2
Tub Seal and Bearing Kit
The tub seal might be torn, causing water to leak from the seal. If the tub seal is leaking water, water may leak through the tub seal and into the tub bearings. This can cause the bearings to fail. For this reason, if the tub seal is leaking water, replace both the tub seal and the tub bearings. Be aware that this is a complicated repair and will require disassembling most of the washer.
Cause 3
Tub Seal
这个答案有帮助吗?
得分 4
添加一条评论
Hi @ Jessie Gloria,
If there is water leaking into the washer tub, try turning off the taps that the washer’s hot and cold hoses are connected to and check if there is water in the tub in the morning.
If there isn’t any water in the tub, you have a leaking water inlet solenoid valve in the washer. They cannot be repaired, they have to be replaced
To prove which one it is, either the hot or the cold solenoid valve, close one tap at a time and then check a bit later for any water leak in the tub to prove whether it is the hot or the cold water inlet that is the problem.
What is the make and model number of the washer?
You can search online for (insert washer make and model number) parts to get results for suppliers so that you know how much a replacement solenoid valve is.
Some suppliers even have videos on how to install them.
You may also wish to check the hose filters in case they are broken and allowing grit etc to enter the solenoid and possibly preventing it from sealing properly when closed.
The filters are located at the end of the hoses where they screw into the machine.
这个答案有帮助吗?
得分 2
添加一条评论
Does this only happen on the initial fill? Or does it happen rinse cycles too? Where is the leak coming from?
Sometimes, the rubber seals on the water inlet hoses don’t work well or the hoses aren’t tight/snug.
The fill cycle pulls water from the inlet hoses and sometimes (due to water pressure), the jolt caused by this can cause hoses to loosen over time.
My first recommendation is to check the inlet hoses, and verify that they are tight and still serviceable. After that, start a cycle (on hot and cold temp so both hoses pull water) and check for leaks. The leak persists, allow it to run and search for the source.
However, the hoses are often times the culprit.
Hope this helps.
这个答案有帮助吗?
得分 1
1条评论:
great advise thank you for that! I also have at times found water under my Cabrio Platinum washer and recently it seems the sound when spinning is a bit different , would that tend to indicate tub seal and bearings?
完成的
添加一条评论
I have water under my Cabrio Platinum washing machine. I found the leak on mine. I removed the back panel and watched as I ran a load of wash. There is a very small intermittent leak at the top of the tub plastic tub. It appears to be water splashing up and out of the tub. Small drops migrate out and drip down to the floor.
I've taken a photo of the back of the machine with the back panel removed and you can clearly see the white water staining on the plastic tub. These are the leaky spots.
Hope this helps, unfortunately I don't know how repair this issue.
这个答案有帮助吗?
得分 1
2条评论:
Hi,
Don't know the washer but if it is a top loader, does this happen when the water level is set to medium or low or only when set to high?
Just wondering if it is a water level pressure sensor switch problem and too much water is filled when high water level selected.
What is the full model number of the washer?
完成的
Just wondering if you considered spraying or painting on flex seal onto the tub where it is leaking?
完成的
添加一条评论
Hi @chileverde78,
I’m wondering if the problem is with the water level pressure switch allowing too much water into the machine for a full load.
Unfortunately the spare parts diagrams don’t show the switch as a spare part, only the location of the hose that connects to it and it is not very helpful. See part #5 Motor, Tub and basket parts diagram
这个答案有帮助吗?
得分 1
添加一条评论
I finally found the leak:
The pump was leaking out of the spade connectors. I bought a cheap internet replacement pump, installed it, and no more leak.
这个答案有帮助吗?
得分 1
添加一条评论
My washer started leaking again this time out of the fabric softener bin at the top right of the washer - the little tray where you load the softener. After several attempts at cleaning and modification, it still leaks. I’m over it, I’m buying new appliances.
这个答案有帮助吗?
得分 0
添加一条评论
There are little valve seals/gaskets where the hot and cold water solenoid fill valves plug into the machine, which are held in by some screws and easily accessible from behind control console. Just undo your h/w supply hoses and take cover off behind control console -a few screws and you can easily see if thats your problem. On one unit I fixed using some permatex gasket cement on the old gaskets. On another I used p/n 134371300 Washer Dispenser Inlet Gasket (~$5)from a similar whirpool machine; that seal is not an exact match (they don’t sell these for the Cabrio separate from the $50 valve which is ridiculous) and I wrapped it with teflon tape to make a snugger fit, which is working ok so far.
这个答案有帮助吗?
得分 0
添加一条评论
The water that comes into the washer has no common sense. I'd city water department would teach water not to leak out then there wouldn't be any posts about leaking washing machines.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
muddy4brats 将永远感激不已
浏览统计数据:
过去 24 小时: 29
过去 7 天: 123
过去 30 天: 578
总计 48,276
