跳转到主内容
Model no. ML-2510, monochrome laser printer
Why won't my Samsung M2020W laser printer operate wirelessly?
My Samsung M2020W printer used to work wireless but will not do so now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Does your computer see it? What kind of operating system are you running? Will the printer work with a wired connection?
完成的
Using win 10. Works well with a wired connection
完成的
Hi,
did you get your problem fixed?
I'm having the same problem. Suddenly the printer went offline.
Checking the known IP via browser wasn't successful either.
Connecting to USB showed the printer in easy wireless setup.
However the settings applied there didn't solve my problem.
As if the WiFi connection of the printer is dead!!
Any suggestions?
Benjamin
完成的
添加一条评论
1个答案
It might be missing drivers or an accidental removal of drivers. What have changed since it was ok? have you installed some program? have you uninstalled something? have you changed some network settings (I am talking about windows platform)
这个答案有帮助吗?
得分 0
2条评论:
have you changed your router?? if so uninstall and reinstall drivers and rediscover the printer.
Set a fixed IP on the router in IP address reservation page of your router's
admin page
完成的
Have you unchecked Network adapter settings?? that is a good point to start.
完成的
添加一条评论
添加你的答案
Scotty Day 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 517
