跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2265 个问题 查看全部
Home button does not work and turning on take too long
Hello.
I had to replace the screen of my iPhone 7 like three times. The first time everything works fine. However, the screen was cheap, so it failed after two months. Then I replaced it again, but this time the home button did not work. I broke the screen again and this time the home button still does not work but when I turn the phone on, it takes like three minutes. Did I misconnect something inside?..
Any suggestion?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I will try to help you. Form what I know some iPhones have it so that it only works with the home button it came with. If you have the original home button then you can swap it out and hopefully it will work. You can also bring it to your local mall, they may have a place where you can get it fixed. Sorry if this was not help full, bets of luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Albert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 30
