How would I fix a loosened micro usb port on an xbox one controller?
so when I plug a micro usb cable into my xbox one controller, the port on the controller would wiggle when touched and would barely power on the controller. If the controller were moved slightly, the cable connected to the controller would turn off the controller until it’s placed on a flat surface.
I think I caused the problem by accidentally dropping my controller while my cable was plugged in.
with that being said, is there any solution (besides buying a new controller) that can help?
Thank you in advance for the responses
1条评论
Use long rubber band to somehow make an X shape in middle of controller. Might need to carefully adjust the rubber band until it loops around the neck of cable
由 Arthur Peau 完成的
