跳转到主内容
How do I fix the flashing folder error?
I have opened the back to try and access the hard drive as I believe that something may be wrong with the connection between the hard drive and the CPU.
I’m now officially stuck, can’t find the hard drive in the back of the laptop. I can locate the drive chip, not quite sure if that has anything to do with the fishing folder error.
Fairly new to this sort of DIY, help would be much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This is close to the first machine to use a flash drive:
MacBook Air 11" Late 2010 Solid-State Drive Replacement
So no hard drive. If you have a bootable external USB drive, plug it in, boot up holding gown the Option key, select the external drive. Now run Disk Utilities on the internal drive.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Elkan Weilert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 88
