跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
Going to install LCD screen
Hello, I am going to install the new LCD screen to replace my broken one.
Can anyone let me know any tips of DOs and DONTs? For example, the screen cannot be flipped more than 90 degrees because it will damage the ribbon. Any other tips I should know?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The best tip is to follow this guide very carefully. The iPad Air doesn’t have many gotcha’s but consider these:
  • Always disconnect/isolate the battery before disconnecting/connecting the LCD
  • The LCD is very fragile, handle with care
  • The screen flips to the right and the LCD flips to the bottom so you will need an extra hand or something to lean the LCD on until everything is disconnected
  • If you damage the digitizer during removal, don’t buy a cheap digitizer (you will regret it)
  • You have to be careful with how you fold the digitizer and home button flexes when re-assembling (they fold towards the inside of the device
  • You will need to remove the old adhesive and clean the ridge with acetone/IPA to remove all of the residue.
  • Then apply a good quality adhesive like this Tesa 61395 Tape you can find here on iFixit or pre-cut 3M tape from Bowler-Tech, which is what I use.
Custom cut rolls of Tesa 61395 double-sided tape for repair.图片
产品
Tesa 61395 Tape
$5.99
这个答案有帮助吗?
得分 1
2条评论:
I recommend that you get the adhesive remover so that you can remove the old adhesive quick and easy without the risk of damage.
iFixit Adhesive Remover
完成的
@ajcooke01 It's just Acetone...see Augustine's (@salmonjapan) & Robert's (@robert33415) answer here:
Is the iFixit adhesive remover just isopropyl alcohol?
Besides, as a chemical, iFixit can only ship it within the US.
完成的
添加一条评论
添加你的答案
tikus belon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 106
