跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
Where do speaker wires connect?
When I replaced LCD and glass I broke the blue wire to the speaker not sure where this wire should be connected, Audio is great to ear buds but need to get speaker working, need info on connection and how to get to the underside of board if wire is connected to that side of the board.
Thanks Dave AA6DB
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
David Bird, take a good look at the guides on here and that might just give you the answer you need iPod Touch 4th Generation good luck
完成的
添加一条评论
1个答案
已选择的解决方案
Speaker leads wires can be connected as follows, looking at the itouch with top away from you you will see two solder tips one on the left connect red lead the blue goes to the next solder tip to the right of the red one. Not necessary to remove board.
Dave AA6DB
这个答案有帮助吗?
得分 1
1条评论:
David Bird, great job. All you have lefty to do is to accept your own answer. That way everyone will know from now on how to do it. Great job...
完成的
添加一条评论
添加你的答案
David Bird 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 4,507
