跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
Is there a difference between the LCD cable MBA 13" and the 11"
I am trying to rule out reasons why I’m having display problems (Backlight flickers after water damage) on a 13” MBA and in order to do that I have the possibility to use my 11” MBA of the same year. Now the only question I have is… Is the LCD connector of the 11” and 13” identical? This way I can temporarily connect the 11” on the 13” MBA.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I have no idea if the connectors differ but frankly I would just buy the proper part.
完成的
it's pointless to buy the proper part, if you can't tell yet where the problem lies.
完成的
添加一条评论
1个答案
最有帮助的答案
Bad idea. Hook it up to an external monitor instead. According to what TV you have, if it is a HDMI, just get a Thunderbolt to HDMI adapter like this one:
USB 3.1 Type-C to HDMI Adapter
https://www.amazon.com/AmazonBasics-USB-...
这个答案有帮助吗?
得分 2
1条评论:
I definitely expected it to be a bad idea, I just wanted confirmation just in case.
Now, as stated in my other post, hooking it up with an external screen gives zero issues. So my guess would be that either the connector on the logic board got screwed (short circuit) or the LCD is dead.. There's a video that shows the screen's weird behaviour.
https://www.dropbox.com/s/4z3ahyrwcl5uzi...
完成的
添加一条评论
添加你的答案
Krysztoff Dorion 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 36
