跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1698 个问题 查看全部
black things in the ice
my fridge's ice maker makes ice but there's black things on the ice. it looks like paint chips, mainly on the outside but some just below the surface.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
已选择的解决方案
If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
这个答案有帮助吗?
得分 3
1条评论:
It’s supposed to be a non-stick coating, like Teflon, but my guess is that the actual coating is: anything they have on hand to ship it fast and cheap. It deteriorates in cold, so it’s a terrible replacement for the temperature range it’s supposed to operate at. I see this as a long-term health hazard, basically being poisoned by God only knows what chemical lining is in your ice maker. It feel that it’s sold to us defective, and therefore fraud. Who wants to join a class action?
完成的
添加一条评论
I have this problem and it is definitely the surface of the ice maker peeling off. This will be the 4th icemaker in 10 years. Sorry to hear there will be no fix for this. I have ordered new ones from sites on the internet, not from Sears.
这个答案有帮助吗?
得分 1
1条评论:
Might as well buy the cheapest countertop ice maker you can find. I'm on my third ice maker in 5 years! The coating has come off on everyone of them, no matter the price. Am currently looking to buy my 4th one.
完成的
添加一条评论
Changed one out today that is 2 years old and that coating is slowly coming off and the new one i had to replace it looked like it already had rusty spots so it'll fail too. Fixing to tell Electrolux that when they call back and tell me its happening again i will have to have a refund.
这个答案有帮助吗?
得分 0
添加一条评论
It could also be a washer in the shut off valve downstream from the ice maker. Washers eventually disintegrate, and the sediment will end up in the ice. If it's rubber or neoprene pieces, they are harmless. Proving what it is, or where it came from is difficult. Do you know anybody in a lab who can analyze the specks? You could also put a small in-line filter in the 1/4" feed line to the fridge.
这个答案有帮助吗?
得分 0
1条评论:
No i can see where the coating is coming off on the icemaker cube slots.
完成的
添加一条评论
I have had the same issue, and it is definitely a coating that is peeling off of the tray. It may be a Teflon-like coating that prevents the pieces from sticking to the tray. Sometimes it covers almost the entire curved surface of the piece of ice. This will not get better, and the only solution is to replace the icemaker.
这个答案有帮助吗?
得分 0
添加一条评论
A simple flashlight inspection of the ice maker door/flap showed the black foam weatherstripping is in tatters. I’m googling for a replacement now…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rui 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 37
过去 30 天: 205
总计 30,139
