跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
iPhone 7 Plus rear camera not working after I dropped it
So i recently dropped my iPhone 7 Plus and now my rear camera isn’t working. The front camera works perfect but the rear doesn’t. The rear only works when i click the “x2” button, but that’s it. And it also fell on the front so i don’t know why the rear camera isn’t working. I have tried mostly everything. What can i do to fix it? Will i need to replace the camera?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
My guess is that you may have damaged the camera in some way, shape or form. I would try replacing the rear camera and see if that helps.
iPhone 7 Plus Dual Rear Camera
iPhone 7 Plus 后置摄像头的更换
iPhone 7 Plus Dual Rear Camera图片
产品
$99.99
这个答案有帮助吗?
得分 2
添加一条评论
Just replace the complete rear camera unit. It will work again. It happened to me as well. I dropped my phone and damaged the rear camera internally. So after replacing with original it started working again
这个答案有帮助吗?
得分 0
1条评论:
How much will it cost to get camera replacement
完成的
添加一条评论
添加你的答案
Jason Raghoonath 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 8,480
