跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for all household mechanical fans including ceiling, box, tower, and stand fans.
Fan keeps falling over
Hi can someone help I don't keep to good so I have a tall cooling fan at my bed its on 24/7 over the last month it keeps falling over and the tilt keeps dropping down it as if the fan bit is to heavy for the stand. Thank you Susan
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi,
What is make and model number of the fan?
完成的
添加一条评论
2个答案
最有帮助的答案
In addition to what Dave said, if the pole is wobbly on the stand, there is usually a threaded nut on the bottom of the stand where the pole goes through it. This nut may have loosened up due to vibrations from the fan. Tighten it up.
这个答案有帮助吗?
得分 3
2条评论:
I have this problem too but the pole doesn’t go through the base. I see no way that this fan ever stood up? I never paid attention until it just fell over. I am completely complexed.
完成的
The feet are usually the weak point , they get stepped on or bent in anyway the fan is basically scrap. Unless you can ‘fabricate’ some kind of home repair .
完成的
添加一条评论
Is there a knob on the side of where the fan connects to the stand? If there is try putting it in the position you want and tighten it until the fan stays put. Or, you could fabricate a secondary stand for it to hold it up where you like it to point.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
susangillan35 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 46
总计 5,443
