跳转到主内容
加入维修社区 - 创建账户
20 世纪 80 年代末发布的家用面包机。这款面包机配有标准尺寸的垂直面包桶,并具有多种设置,可制作各种面团和面包。型号为 HB-B102。
Mixing Paddle won't turn
Mixing Paddle does not turn whether in machine or out. Motor and pedestal for paddle work without pan but will not work in pan.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I had a similar problem, you need to perform the steps to replace the shaft seal then clean and lubricate the shaft. It may take a lot of force to remove the shaft. I used a dead blow rubber hammer and a drift to drive mine out. You need to be careful not to damage the shaft or bearing in the bread pan while driving the shaft out. As far as lube I used 3 in one oil but I’ll probably re-lube with silicone plumbers grease.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Janet Hendricks 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 1,473
