HDD disk utility first aid failed
Please help to recover data… as I do not have a back up
iMac 27” late 2012 high Sierra
Failed to start with internal HDD
Booted with OS on USB external disk
Ran disk utility first aid to check internal HDD
Results below:
Volume “Macintosh HD”
- Repairing file system.
- Volume is already unmounted.
- Performing fsck_hfs -fy -x /dev/rdisk0s2
- Checking Journaled HFS Plus volume.
- Checking extents overflow file.
- Checking catalog file.
- The volume Macintosh HD could not be verified completely.
- File system check exit code is 8.
- Restoring the original state found as unmounted.
- File system verify or repair failed.
Volume “Govind's”
- Volume was successfully unmounted.
- Performing fsck_hfs -fy -x /dev/rdisk0s4
- Invalid index key
- Missing thread record (id = 519201)
- Incorrect block count for file 2018.09.18.G80.asl
- (It should be 85 instead of 79)
- The volume Govind's could not be verified completely.
- Restoring the original state found as mounted.
- Problem -69842 occurred while restoring the original mount state.
- Operation failed…
3条评论
Did this happen after a system update or upgrade? Are you running the original hard drive?
由 mayer 完成的
To add to @mayer 's Q's Is this a Fusion Drive config or two independent drives internally?
Is Macintosh HD your Boot drive or is Govind?
由 DanJ 完成的
it happened after it failed to start and I switched on/off a few times. i ran OS on an external drive and checked the internal drive using disk utility.
Macintosh HD was the boot drive. not since it is corrupt it is not booting.
Govind and Macintosh HD are volumes on the single phydical drive.
由 agswamy 完成的
