跳转到主内容
What type of SSD and Wireless Card this model uses?
Hey, I have a dead MacBook Pro Late 2013 and I was thinking about removing the wireless card and the ssd to use it on another computer, but I didn’t find what connector they are, somebody can help me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The SSD is a custom drive made for Apple and uses their own connector. You’ll need to give us an idea on what system you are thinking of installing it into. Or, you can get a USB case to house the drive so you can use it as a portable high density SSD drive. As an example OWC Envoy Pro
As far as the Airport board, there is really no way to re-use it outside of a Mac system or a system which uses the same WiFi/Bluetooth board.
这个答案有帮助吗?
得分 1
2条评论:
I would like something like a adapter for normal PCIE or even sata
完成的
The only thing you can use is a PCIe card for a PC that supports the Apple PCIe/AHCI 2.0 x2 SSD's like this one OWC - PCIe SSD Expansion Card
完成的
添加一条评论
To answer your question, the AirPort card and the SSD would be the two parts I have included below. Those parts will be compatible with the Mac you have chosen to be the device that you have a question on.
MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Board
[关联产品丢失或禁用: IF123-123]
Replace a broken or damaged Airport/Bluetooth board for your Late 2013 or Mid 2014 MacBook Pro 13" or 15" Retina laptop with this part. This part can help fix problems with wireless connectivity.图片
产品
$49.99
这个答案有帮助吗?
得分 0
2条评论:
I already have those, I want to know what connections they use, so I can get adapters to work on another computers, got it?
完成的
Aha, ok. @mayer Any ideas? Is it a form of SATA?
完成的
添加一条评论
添加你的答案
Heitor Scatolin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 105
