跳转到主内容
非一体化电脑称之为台式机。
2134 个问题 查看全部
Possible hard drive upgrade
Hi all,
On my latest build I have my Windows 7 performance readings at 7.3 or higher except for the hard drive stuck at 5.8. My current drive is a WD 500 GB --7200 rpm and I am considering replacing it with either a 10,000 rpm Raptor or a SSD. Due to my lack of experience with either I am looking for some input on the best way to go.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
I personally never just replace a hard drive in my PC, I usually just add a second hard drive. The Windows performance readings really don't mean much. If you're looking for a reliable form of benchmarking, try GeekBench. My main hard drive is a 1TB 7200RPM Western Digital Greendrive. It only gets a 5.9 in Windows. You won't get much better performance, withour upgrading to something like an SSD.
这个答案有帮助吗?
得分 1
2条评论:
Thanks--this is the kind of info I am looking for. +
完成的
Was hoping for more input but doesn't appear likely. The reading I've been doing seems to back up your statement so I'm accepting your answer. Thanks again.
完成的
添加一条评论
最有帮助的答案
I passed on this question because it was PC related but it really doesn't matter. I usually put the Raptor drives in machines that get heavy hard drive access and need a higher level of reliance. A heavy duty Mac truck meant for staying on the road all the time for the long haul vs. the high speed sports car. I'l put my money on the Raptor for reliability.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for your input--do you find the Raptors are noisier than a 7200rpm drive?
完成的
yes, but usually just on start up
完成的
添加一条评论
Even you add an 10.000 rpm disk, should work faster.
Anyway, have you tried to defragment your actual hard disk?
Don't add an SSD or your system will only be faster at boot, but the global system performance will be decreased.
SSD Hard disk drives are only faster reading, but not so fast writting.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
rj713 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 13
总计 1,214
