跳转到主内容
加入维修社区 - 创建账户
佳能 EOS Rebel T3i 于 2011 年 3 月发布,可以通过其 SKU (SKU:5169BO32) 来识别。这款相机也被称为 EOS 600D 和 EOS Kiss X5,是一款具有1800万像素的佳能数码单反相机。
error message "card's write protect switch is set to lock"
when turning on the camera with memory card inserted, i got this message
"card's write protect switch is set to lock" although the card is not lock, tried different card and samething. when i took the card out, it reconized there’s no card and reinsert again, the message come out.
cant take no with push on the shutter button
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Have you found the solution? I have just incurred the same issue
完成的
添加一条评论
1个答案
最有帮助的答案
Hi!
Can you make sure that your card is indeed not write protected? Check the position of the switch on the card:
https://i.ytimg.com/vi/1YPSfvaZceI/maxre...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
simonleongkm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 1,072
