跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
MacBook is slow after upgrading to SSD
My Macbook is much slower after upgrading to an SSD and performing a clean install.
Troubleshooting tips I have conducted:
  • Swapped back the original hard drive which confirmed that the cable is alright
  • Updated firmware to the latest available version
  • From recovery mode set the SSD as default startup disk
  • Reset NVRAM
To compound matters, the SSD seems to perform as expected when connected externally using USB.
I am well and truly stumped at this point.
Edit: For the sake of clarification, when I swap in the stock HDD it’s faster than the SSD. When I plug the SSD to a USB port and boot, the difference in performance is significantly noticeable.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Just checking, but have you tried resetting the SMC? I see you have resetted the PRAM/NVRAM alr so I just want to make sure.
如何重置Mac笔记本电脑上的SMC、PRAM和NVRAM
完成的
I shall give this a go and report back.
完成的
Did any of these suggestions fix your problem? I'm in the same boat.
完成的
Apologies for the delayed feedback.
No luck after resetting the SMC. I know my hardware is working fine so I'll try a clean install and see if there is a difference.
完成的
添加一条评论
2个答案
已选择的解决方案
Yes, the cable may continue to work with the original HDD. Now that you are using an SSD, you will experience increased speed and efficiency and, in turn, increased temperatures. Your SATA cable is likely already in need of replacement, but due to the much slower HDD, problems will be much harder to identify/pinpoint. The issue is directly related to the placement of the SATA cable and the MBPs' metal chassis design.
I experienced identical symptoms with my MBP and replacing the SATA cable resolved everything. SATA cables are fairly cheap on Amazon (try to find one with at least a 1 year warranty). Additionally, I would recommend placing a strip of electrical tape to insulate the ribbon that comes in contact with the uppercase.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Your issue is a known one, your HD SATA cable needs to be replaced as its damaged.
Follow this IFIXIT guide: MacBook Pro 13" Unibody 中期2012 硬盘线缆替换 and heres the needed part: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable. You’ll need to place a strip of electricians tape on the uppercase where the cable crosses over as the rough surface wears the cable. In addition you don’t want to bend the cable sharply at the corners as the crisp bends damages the cable, instead you want smooth arcs. Do make sure you get a good quality cable as many on Amazon or eBay are junk.
This cable connects a SATA I, SATA II, or SATA III hard drive to the logic board.图片
产品
$34.99
这个答案有帮助吗?
得分 3
2条评论:
I did mention that the cable is the first thing that I tested. It works perfectly fine with the original hard drive.
完成的
Yes, I did see you wrote that! The thing is the cable you got was likely a cheap knock-off or was damaged. I find a lot of people tend to crease the bends a bit hard so the delicate foil wires get damaged as these are fragile from excessive bending. Do make sure you get the one I've listed as some folks are also selling the older 2011 models which are not SATA III (6.0 Gb/s) rated!
完成的
添加一条评论
添加你的答案
Mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 7,796
