跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1698 个问题 查看全部
Whirlpool Refrigerator Model Number:WRS322FDInterior Lights Flickering
Has anyone found a PERMANENT FIX for strobing issue. Replacing the LED light panel only worked for 32 days. It now is intermittent. Is there another part in the back of fridge that is causing this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
what's the model number? I remember this may be a manufacture defect.
完成的
添加一条评论
1个答案
最有帮助的答案
I think this will answer your question:
First see if it's covered under warranty, this is a factory defective part.
http://www.applianceblog.com/mainforums/...
Here's the part:  http://www.appliancepartspros.com/whirlp...
这个答案有帮助吗?
得分 2
1条评论:
@mayer…thank you for the response but:
1) no longer under warranty
2) your link takes me to “Page not found”
Could you reply again with the part number for me. I have already replaced the led refrigerator panel with the correct replacement and that has failed. Hoping you have a different part for me.
完成的
添加一条评论
添加你的答案
phaskell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,817
