跳转到主内容
How to disable built-in keyboard on a MacBook Pro?
How can I disable my built in keyboard, so that it stays disabled even after rebooting the computer?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
10条评论
The most simple answer would be to disconnect the keyboard cable, but that would also disable the power button therefore not allowing you to turn on and off your Mac as easily. @mayer Ideas?
完成的
Is there any terminal command that would do the job?
完成的
@am1999 I don’t know if there is one. Maybe Mayer can find a better way then just disconnecting a cable.
完成的
Where is this cable?
完成的
Is it safe to take off the metal case and disconnect the cable while the mac is on?
完成的
显示更多的5条评论
添加一条评论
1个答案
已选择的解决方案
Disconnect the cables seen in step 67 and step 70/71. Those will disable the keyboard entirely, so please be aware that you will not be able to use the power button! You do not need to disconnect or remove anything else.
更换MacBook Pro 13'' Retina显示器2013末期版本的上部机身(C壳)
这个答案有帮助吗?
得分 1
4条评论:
Is this process reversible?
完成的
@am1999 Yes, just plug the cables back in.
完成的
Do i have to remove the battery to do step 71?
完成的
@am1999 If you can locate that cable no you do not.
完成的
添加一条评论
添加你的答案
Alex Marcan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 403
