跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Will flux affect the home button?
Hi there,
Currently in the middle of doing an iPhone 7 small flex repair as it was ripped by someone. The pressure sensitivity doesn’t work but the rest of the functions of the home button work. I’m worried about the flux that i’m using affecting the sensor inside of the button itself as I’m working closely to it. I have covered some of the whole with thermal tape to hold the button and to keep the flux out but some has got in. Don’t want to find that when I finish the repair the home button doesn’t work because flux went in. Would appreciate the help on this one. Not sure if it will affect it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If you are using a Rosin based flux (RMA or RA - unlikely as that is a dark flux) then you would definitely have to clean it off.
If you are using a No Clean flux, then you shouldn’t have to worry about it. That said, it really depends on the flux. I am currently using the Chipquik 291 and I don’t like it at all. I find that it tends to crystallize and it can be hard to remove. You could try to put some IPA or better yet, real flux remover, that will dissolve most of it.
这个答案有帮助吗?
得分 3
2条评论:
I'm using Amtech RMA-223 and have used isopropyl alcohol to remove parts of it. But there is still some in the hole, should I put some alcohol in there? I'm worried about the sensor in there and if that would damage it.
完成的
I've never tried it myself but I don't think it will be detrimental.
完成的
添加一条评论
inside the home button where you are worrieing the flux might have damaged the home button is not right. There is Touch ID and flexcable including all those nano jumpers are covered with black underfill, and there is not any kind of button etc, And also Touch ID works it mean there isn’t any problem.
check the Crystal ic near where you working called u10 or AD7149. If it’s cracked that’s the normally couse this issue.
and if it’s not cracked the the connector on home button if it looks funny coz sometimes that needs replacing also, the best thing is that check all the pins resistance on the home button connecter with the multimeter on diod mode.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for helping, I know what the problem is, it’s the smaller flex which was torn by another person that’s why I have jumpers going to the components from the flex from the button. I was just worried about the flex going inside the hole where the flex cables come out because I can see a sensor there and was wondering if the flux would affect it. Thanks
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 76
