跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
New phone but Vivosmart 3 is still trying to connect to the old phone
I broke my old phone transferred the sim to new iPhone 7 but the Vivosmart 3 is still trying to reconnect to the old phone. Tried everything. Deleted the ap, reinstalled, turned off the phone and back on, turned off Bluetooth etc etc
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
You need to pair your VivoSmart 3 with your new phone.
https://www8.garmin.com/manuals/webhelp/...
完成的
I can’t do that until I get the Vivosmart 3 to unpair from the old phone. The phone was water damaged so doesn’t work anymore so can’t do it from the phone. Please someone help !
完成的
Thank you but The Vivosmart 3 just shows the band is trying to reconnect to the phone, no option to pair as it thinks it is already paired, but the phone it is paired to is now dead. I need to find a way to get the Vivosmart to forget the old phone.
完成的
添加一条评论
1个答案
最有帮助的答案
I’m pretty certain there is a way to manually reset the pairing on your watch. Just like any other bluetooth device it should be capable of doing so.
Re-pairing instructions I found online
  1. Open Garmin Connect app;
  2. Double tap on the face of the Vivosmart to activate the device;
  3. Press and hold the face of the Vivosmart until the settings options appear;
  4. Swipe through the settings until you see the Bluetooth symbol;
  5. Press the Bluetooth symbol;
  6. Press the right arrow once;
  7. Touch Pair;
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tricia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 248
