跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2265 个问题 查看全部
Phone is searching. Does not know the SIM is in or out of the phone.
Need some answers if possible. I have an iPhone that does not recognize if a SIM is in the phone or not. It is stuck in a searching mode. It states that it needs an update, but after hooking it up to iTunes and updating, it just goes back to saying the same thing? Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The iPhone 7 has several design issues. The Qualcomm baseband version logic board has multiple issues that can cause “searching” or other connection issues. At this point it sounds like a hardware issue so you will need to have it looked at by an experienced micro-solderer. However, if the problem is within the baseband IC itself, it will not be repairable.
这个答案有帮助吗?
得分 1
1条评论:
If no IMEI is displayed via dialing *#06# in dialer, modem and IMEI missing in settings general about phones those are symptoms of baseband circuit failure.
完成的
添加一条评论
添加你的答案
Shawn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 38
