跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
20 个问题 查看全部
Replacement of cracked ipad screen
My ipad screen cracked like in the picture. Ipad display can be seen and the touch responses well.
I want to fix it myself and am planning to buy the screen. But there’s a lot of choices; cheap or expensive ones.
Can i buy a screen like this? https://www.lazada.com.my/products/white...
Update (09/28/2018)
Can you give me an example of what kind of parts should I buy? I’m also confused on what to buy because I found out there’s a few variations of screens; lcd/digitizer/touchscreen/etc.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sure you can do this yourself! You have to have a steady hand and be patient in your work otherwise you will create problems for yourself. I would recommend you read through this guide first to see if you are comfortable with the steps and tools required.
As for the parts, I can’t speak for the supplier you linked. However my one piece of advice here is don’t go for the lowest cost parts, ultimately, you always get what you pay for. Look for a reputable vendor that offers a real warranty and return policy. then if they have a premium or OEM version of the part, go for that if your budget permits.
这个答案有帮助吗?
得分 4
1条评论:
Everything is listed out in the guide.
完成的
添加一条评论
添加你的答案
tikus belon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 305
