跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
Issues with optical drive
I was cleaning my brother’s playstation 4 because the fan was overworked and the console was hot. When I opened it I left the game disk inside the drive and went on carefully disconnecting all cables and cleaned the system and it’s hardware. After I had put the console back together it still ran extremely hot but the fan still worked. The disk drive on the other hand stopped working entirely. It will take in a disk, making some sound like it was loading or even grinding for second then not recognize the disk. It will eject the disk and upon opening the drive itself there was nothing foreign inside and the disk was centered correctly. I cleaned the lens and still no luck. All cables and connections are correct and connected properly. There was no physical damage to any cable or the drive. I just dry wiped it. Also he has issues with his wifi as he gets about 20-30mbps slower than what I get on my xbox one even when they are next to each other and wired.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You may want to try a new optical drive. iFixit sells an optical drive for this console and also provides a part. You can return the optical drive and get a full refund if we determine it is not the optical drive.
PlayStation 4 SAA-001 Motherboard & Paired Optical Drive
更换PS4的光驱
Replace a corroded, damaged, or malfunctioning motherboard and its paired optical drive. This SAA-001 motherboard and paired optical drive are compatible with a model CUH-10XXA PlayStation 4 console. Heat sinks are not included.图片
产品
$168.99
这个答案有帮助吗?
得分 0
2条评论:
The model of the ps4 is 1215a would there happen to be one for that?
完成的
@jonathanmnicoli The one I provided should work. If it does not you can return it.
完成的
添加一条评论
添加你的答案
Jonathan Nicoli 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 81
