跳转到主内容
OWC with SSD via USB from old MAC not recognized on another MAC
My MAC died. Placed the SSD blade into a OWC Envoy Pro with a perfect match. When I plug it via USB into a working MAC it does not show up. If I use disk utility I see it as OWC Envoy media. However, I am unable to see the drive so that I can remove files.
Thanks
Marc
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
3条评论
What was the OS version you had on your Mac system and what is the OS version on your new system?
完成的
MAC OS sierra on both.
完成的
I have the same issue and I'm running Catalina . but can't read the SSD.
完成的
添加一条评论
1个答案
已选择的解决方案
You may need to upgrade your MacOS to High Sierra on your new system if your dead system was running anything older. As your systems firmware needs an upgrade to recognize the newer file system APFS.
这个答案有帮助吗?
得分 3
3条评论:
What is going on when I plug a GUID external into a machine with APFS and it won't see it? P.S. I can migrate from it, but not see it otherwise.
完成的
Both HFS+ and APFS use GUID so I'm not sure I follow you here...
I think you're asking if a APFS drive can be accessed by a HFS+ based system. Well, yes & no ;-}
Apple claimed Sierra would recognize an external drive but I've not personally tested this. Anything older the answer is no.
完成的
Upgraded the OS to Mojave and that solved the problem. Thanks so much for the solution!
完成的
添加一条评论
添加你的答案
Susan Turow 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 2,124
