跳转到主内容
加入维修社区 - 创建账户
2010 年 1 月发布的 HP 笔记本电脑,配备 10.1 英寸显示屏,重 2.7 磅。有纯黑、红、蓝、银四种颜色可选,配备六芯电池。
Turns on but screen doesn't
My hp mini 210 turn on but screen is blank
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Can you give us some more details about what you might have done to your device to cause it do this?
由完成的
Hi @magicjet_
Any beeps or pattern LED flashing?
when you power on the computer, observe on the HDD LED if there is any activity.
when you hook to an external display.... do you get display?
you might need to invoke some key to project out to the external display.
else
another test you can do is to test with another known working RAM first
HP Mini 210 内存条更换
由完成的
I have done all of those things.
由完成的
Hi @magicjet_ ,
Do you get a display showing on an external monitor connected to your laptop via the vga port, when you press the F4 key, when the laptop has been turned on and presumably booted into Windows?
由完成的
No It doesn't do anything
由完成的
显示更多的2条评论
添加一条评论
2个答案
已选择的解决方案
I think these had a common problem with the ribbon that connects the screen in the top half to the motherboard in the bottom half… if I'm thinking about the same netbook u needed to replace the ribbon to get it to work properly or fiddle with it and squeeze it etc to get it to work temporarily
Basically try replacing the ribbon it's quite a fiddly job though
这个答案有帮助吗?
得分 0
1条评论:
Can you give me a link to where I can buy one?
由完成的
添加一条评论
Test ram in my experience when ram is not functioning well it will turn on without screen .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,756
