跳转到主内容
What causes logic board damage?
Hi
My mac got a hit on the screen and its damaged so I took it to a maintenance service(authorized from Apple) and they said the display need replacement and the the main logic board also
so my question is: Is it possible that the main logic board damage caused by the hit on the screen? If not what caused that? Because I didn't notice anything before the accident.
thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It can happen when display gets crushed some power/data lines are pressed together and get shorted, allowing current to go along lines where it shouldn’t. This might damage the connector on the logic board and connected components until the fuse, which is there to prevent the damage goes even further in the heart of the board. An authorized Apple center would usually propose a logic board replacement, but there are around also professionals who can probably fix the board for a fraction of a new logic board cost.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Saeed Khader 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,109
