跳转到主内容
Repair information for the Nextbook Ares 10A. Released in December of 2016. Model number: NX16A10132S.
50 个问题 查看全部
My Nextbook will not charge.
I have been trying for over 48 hours to get my Nextbook to charge.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Does it power on or is it just completely dead?
完成的
It will turn off and show that the battery is dead. when I attach the charging cor d no indicator light comes on to say it is charging and it is dead. I have tried several times unplugging and plugging it back in. Nothing.
完成的
My charger light comes on for a few seconds and then goes off and nextbook never charges.
完成的
添加一条评论
1个答案
已选择的解决方案
  1. ok take another well known working charger and try that could be a bad cable
  2. look near around port give it a blow or wipe ensure its clean no loose particle
  3. lastly if none work you , take the charger back to another advice verify charge if not there may a charger port damage and need professional replacement.
Cheers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rita Durham 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 8
总计 1,077
