跳转到主内容
The TI-83 Plus is a graphing calculator released in 1999 as an upgrade to the TI-83.
Screen appears to all black but not from screen rupture
When I try to turn the calculator on the screen flashes from solid black to normal but the calculator will not function because of this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Some more information would be appreciated. Do you mean that the cursor still flashes but none of the buttons work? You may want to try replacing the batteries including the backup battery with fresh ones.
If you get a constant, solid black screen when you turn it back on, press [2nd] then release it, then hold the down arrow key until the contrast is where you want it.
Have any of the guides for your calculator helped?
这个答案有帮助吗?
得分 0
2条评论:
It is not from contrast. Now, instead of being all black, the screen is glitchy with unreadable black areas scattered everywhere. I replaced both the back up battery and regular batteries.
完成的
Oh! Then it may be from a degraded ribbon cable. The TI 83 is notorious for this issue. There's a guide for repairing that here: https://www.cemetech.net/forum/viewtopic... and a guide for taking the calculator apart here: Texas Instruments TI-83 Plus Motherboard & Screen Replacement
完成的
添加一条评论
添加你的答案
Laura 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 360
