跳转到主内容
加入维修社区 - 创建账户
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
Recently replaced Digitizer Issue
I recently replaced the digitizer (iFixit part), it seemed to be OK but after a few minutes it starts to type on it's own or if you attempt to swipe to the next page it will swipe back. I have taken it apart and everything looks good. Is it possible it's a bad digitizer?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
It’s possibly a digitizer issue as the iPad mini is notorious for those kinds of issues. iFixit mini replacement parts are quite good quality however so as Lee suggests, contact support to see what they can do for you. The iPad mini has a few gotchas as far as the digitizer goes, @jessabethany did a great write-up several years ago and it still applies today.
这个答案有帮助吗?
得分 3
添加一条评论
Head on over to iFixit support/warranty dept! They stand behind their stuff.
这个答案有帮助吗?
得分 2
添加一条评论
You need to locate two foam ridges on both sides of the home button on the housing chassis, they are adhered onto a tape that is holding the LCD, you can either pull off the foam ridges or scrape them off.
The foam ridges often interfere with touch functionality (especially when install an aftermarket digitizer)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jeff Poulin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 182
