跳转到主内容
An audio storage device that uses magnetic tape to record and play back audio input.
29 个问题 查看全部
Playback of recorded material is "garbled"
Is that garbled sound, that you are discribing, like if you sing a not and lightly punch yourself in the chest? Because that’s the problem that I have with my deck. I ordered Awesome Mix tapes from the movie Guardians of the Galaxy (meaning they are new) and when I play them on my walkman they sound fine, but when I play them on my Sony TC-K370 the sound is as I described... Is the problem in the belts? Or the little wheel?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The belt probably needs replacing.
Try cleaning the heads, capstan, and pinch roller. If it's been sitting for a long time in an attic, it's probably dirty and oxidized. This video shows you how to clean a tape deck:  https://www.youtube.com/watch?v=Y2LQr63X...
Here’s the service manual:
https://www.manualslib.com/manual/101242...
这个答案有帮助吗?
得分 1
1条评论:
Thank you! Will do!
完成的
添加一条评论
添加你的答案
Mateja 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 16
总计 96
