跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Why won't my lid stay closed?
While the lid of my Macbook Pro can close all the way, if you close the lid and then take your finger off, it bounces back up about an eighth of an inch.
From what I can tell, the force of the locking magnets is being overcome by the opposing force of a hinge that doesn’t want to shut all the way. The screen has never been replaced and the case has never been opened. The laptop has taken a minor two-foot drop once, but that was a long time ago.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Did it impact on one of the corners?
完成的
No, the impact was on right rear side between hdmi and usb ports. Just a small little dent, less than a fleck of paint in size.
Also, I think I know what may have caused this problem: My laptop is my only computer, and I work from home. Therefore, the lid is always open unless it's in transit. So 95% of the time the lid stays open. Over time, I think this deforms the hinge mechanics such that at some point it becomes noticeable, after which point it quickly becomes worse, to the point where it won't stay shut.
完成的
Is it dangerous? I have the same issue. Its a 2011 mac pro
完成的
Another reason why your laptop can't fully close anymore (or can't remain closed) is a defective battery. Over time Litium Polymer batteries will outgas as they age. This gas is trapped in a sealed plastic pouch surrounding the battery cell, hence the cell takes more time and will push against the keyboard and trackpad. This may prevent you from fully closing the lid.
完成的
添加一条评论
3个答案
已选择的解决方案
I have the official answer from Apple itself: my lid wouldn’t stay closed because the battery had swollen, causing the case to bend. (No, unfortunately my Early 2015 13-inch MBP is not a part of an exchange program by Apple. Oh well.) The more the battery swole, the worse the flex/bend. This not only prevented the lid from closing properly, but also explains why there could still be keyboard marks on the screen even though the lid wasn’t able to fully close.
This quote sums up my experience exactly:
It may start with a trackpad that just doesn’t click like it used to. Or you may notice that your laptop doesn’t sit flush to the desk anymore. Eventually, your laptop’s case may start to warp and bulge, and you’ll know for sure that you’re dealing with a swollen battery. While a swollen battery can be dangerous, we’ll show you how to deal with one so that it becomes nothing more than a minor inconvenience.
The repair cost $100 for labor and $180 for parts, so $280 plus tax. They replaced the entire case including keyboard and trackpad, though they did leave the bottom plate intact, which was disappointing because I had installed some vinyl pads after the original feet wore through. Not sure if I have any different hardware than before other than those two things, but they were authorized to use refurbished parts if needed. When I asked what that meant, the team member said that these are parts that may have been pulled from other machines, but tested and confirmed working properly. Gave them my macbook on early Friday afternoon, got it back early Monday afternoon.
Knowing that the swollen battery’s out of the way, now even more interested to upgrade that hard drive given this may be the best 13-inch macbook ever built. (And now re-built, again, after it’s already had one keyboard replacement.)
I’ll never buy another Apple product again without AppleCare. It used to not be necessary, but these days it’s a requirement.
这个答案有帮助吗?
得分 4
4条评论:
@sac86738 - Happy it worked out! You may want to check the MagSafe charger out in case its bad. Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters Also try to make it a habit not to allow your systems battery to discharge below 3/4. When you do it runs the charging circuit longer which can cause the battery to swell up. Best to keep an eye on the cycles as each cycle is a death nail in the battery to fewer the longer your battery will last.
完成的
"While a swollen battery can be dangerous, we’ll show you how to deal with one so that it becomes nothing more than a minor inconvenience." What do you mean by this? Is there another option to deal with this other than repairing it? I have the same problem but the laptop is almost 6 years old so I don't think it is worth paying for any repair at this point.
完成的
Sorry for being tardy to the party. ¯\_(ツ)_/¯ I should have struck that sentence from the quote; what came before it was what I wanted to highlight, because it perfectly described my experience: laptop didn't sit flush to the desk anymore. Warping, bulging, etc.
完成的
This is happening to me with mi Macbook Air too!!! It's an 11" early 2014... Ill have to check if the repair it's still available.
完成的
添加一条评论
If your system has not been physically damaged the hinges may need to be replaced. The clutch mechanism in the hinge maybe bad. Here’s the IFIXIT guide you’ll need to follow to get the display off to gain access to the hinges MacBook Pro (13英寸, 带有Retina显示屏, 2015早期) 显示组件更换
Update (09/15/2018)
Here’s the needed parts:
这个答案有帮助吗?
得分 1
2条评论:
@sac86738 Considering that both the corners near the screen are not damaged or dented you should be okay to do this.
完成的
Thanks for pointing me to the right article, and for the +1 on the recommendation.
iFixIt doesn't carry the clutch hinge for a 13" MBP, a major bummer. Who's a reliable source for these sorts of parts, or do you think a local Apple Authorized Service Provider would be best?
Thanks for your help. It's too bad about the RAM being soldered in... completely forgot about that. At least the SSD is upgradable and can be done at the same time I do this. ¯\_(ツ)_/¯ Long live the Early 2015 13" MBP.
完成的
添加一条评论
This issue found on my new macbook pro 2019 one weak later after purchased…if you close the lid and then take your finger off, it bounces back up about an eighth of an inch.
这个答案有帮助吗?
得分 0
2条评论:
In that case what Apple authority said to you? I’ve the same problem with my Mbp 13” 2017 model. Thanks
完成的
I got the same issue with my MBP 15'' 2018 model, too.
完成的
添加一条评论
添加你的答案
Michael Paul 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 53
过去 30 天: 234
总计 40,878
