跳转到主内容
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 个问题 查看全部
Why is there a boot menu every time I turn on MacBook?
How to fix this?
Every time when I turn on my macbook pro mid 2014 I have to choose my startup disk to continue with booting. It behaves as if I am holding the option key...
However, the right option key doesnt work when I want to use it in the OS.
When I turn on MP and hold the left option key it starts booting without the boot menu, when I do not hold it it shows the menu.
When I hold the right option key there is no difference.
I have tried apple diagnostics and it shows that everything is ok.
Tried resetting SMC and PRAM and doesnt work.
Running MacOs High Sierra
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
After booting, go under the Apple to:
System Preference>
Start up disk>
unlock it>
select your boot drive
这个答案有帮助吗?
得分 1
6条评论:
It didnt work
完成的
what system are you running?
完成的
Matej - Other than the option key not working while using macOS, is it that much of a bother to you? I mean, it can be a bit annoying to have to hit enter on the startup menu every time but you still get to where you need to go...
完成的
@mayer he/she is running High Sierra (hiss, High Sierra...)
完成的
Mayer - running High Sierra
Aaron Cooke - It is not annoying for me, but it is for my sister :D
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Matej 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 179
