跳转到主内容
Surface Laptop是微软Surface产品线中的第一个全笔记本,在2017年6月发布。
20 个问题 查看全部
Trackpad popped out at the bottom
I accidentally dropped something and my trackpad popped out at the bottom. Hard clicks are now not registered. I tried to pop it back in but it won’t stick. What do I do? My nearest Microsoft store is really far away.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
Mine surface laptop 2's touchpad propped out at the bottom too. Should I use any type of glue to fix it? If yes, what kind of glue can you recommend?
完成的
hi there! i have a same problem as well, i accidently dropped the laptop and the trackpad just came out a little. and i dont have any microsoft store nearby.. please help me..
完成的
@nishim see my fix below
完成的
@abudullah shaikh. please help me. couldn't find your fix
完成的
@nishim it's right above the one you replied to
完成的
显示更多的3条评论
添加一条评论
10个答案
已选择的解决方案
happened to my surface laptop 1, i did a fix that was super ghetto as it was out of warranty. Essentially, you peel off the metal shroud on the underside of the touchpad so it drops back in. Clicks will register again without this shroud, and the touchpad will sit flush again. Hope this helps someone as i found no help online
这个答案有帮助吗?
得分 20
31条评论:
Thank you so much! This worked for me
完成的
I'm afraid to tear that piece off. Should I actually do that? You said it will sit flush again and the clicks will work, but will it still wiggle around and pop out?
完成的
Thank you! Removed the metal thing and it works again.
完成的
Hi, Paige, the trackpad sits flush and doesn't wiggle at all.
However if you're doing something really weird like holding your laptop upside down while it's open, the trackpad does lean out a bit from the frame, since there's nothing holding it in from the bottom anymore. I found this to be much better than the alternative of not having your trackpad click anymore or risk shattering your trackpad trying to bend a metal clip under the keyboard.
完成的
Thank you so much! After a stressful hour of trying to get help from Microsoft, I used your method of removing the metal shroud....and it works! Can't thank you enough!
完成的
显示更多的26条评论
添加一条评论
Here’s how to get the keyboard and trackpad off to reseat it: 微软 Surface Laptop拆解
Take a close look at the battery and examine it for swelling, which could be a contributing factor in it popping out.
这个答案有帮助吗?
得分 1
添加一条评论
you need a thin tool, even a ruler works. the metal piece that is sticking out needs to be put back. to do this you need to push the metal part in with the ruler. push it in lightly, but make sure it goes in the farthest it can go this should fix the problem. the touch pad will be a little bit lifted but the hard click will work
这个答案有帮助吗?
得分 1
4条评论:
thankyou so much! will try this and let you know
完成的
Hi, I want to know if it worked for you?
完成的
Yes, this works. lift the touch pad up about 1cm and push the metal clip right down to the base of the hole, then released the touchpad and let the metal clip pull it all down. it does still stick out a bit, but the hard click now works.
完成的
can someone give me a more detailed explanation on how to do this? im having trouble understanding what to do.
完成的
添加一条评论
Probably too late now but I just had a similar problem and ended up using a very thin putty nice and pressing the back piece of the retainer down and its now better than it was before it broke.
这个答案有帮助吗?
得分 1
2条评论:
I took out the metal retainer and now it works perfect. It is flush as well. Pushing down the retainer did not work for me.
完成的
i had no choice but to take it out as well, sit flush now but pops out if you turn laptop upside down. mine is a surface laptop 2 model 1769
完成的
添加一条评论
This should have a detachable keyboard correct?
If so look up a new keyboard for the surface. Make sure it is exactly the same.
If not then try prying a little bit more to see under the trackpad. Be careful not to break it anymore.
Is anything stuck under it?
这个答案有帮助吗?
得分 0
1条评论:
no this is a surface LAPTOP not pro. you cant take the keyboard off
完成的
添加一条评论
The same happened to me. My trackpad popped up. I tested it and right-click and click to drag did not work. I lifted on the trackpad a little more and took the metal piece out (which was super easy) and it works fine now. I even tried to flip my laptop upside down to see if it will fall out and it doesn't. It lies flush now. Thanks Abdullah Shaikh for suggesting.
这个答案有帮助吗?
得分 0
2条评论:
Can you tell me how exactly you took the metal piece out? Did you just rip it off while slightly lifting the trackpad?
完成的
Glad i could help!
完成的
添加一条评论
It seems to me that the trackpad is glued to the little metal trackpad frame. When the epoxy comes away from the bottom of the trackpad, the screw nub sticking up at the center-bottom of the trackpad bay no longer makes contact with the clicker button located on the under-side of the trackpad.
The issue lies with the rather-thin metal piece coming away from the bottom of the trackpad … the separation creates a buffer of space and the clicking device no longer makes connection with that little metal nub.
Putting a very fine coating of adhesive and using paper clips to adhere it to the trackpad was my initial idea, but then I realized you’d have to bend the tab on the bottom of the metal trey to insert it back into the tab beneath the soft ‘alencantara’ keyboard coating. Or whatever the heck it’s called. I’d look it up, but … you know what I’m trying to say.
Moving on … I decided to put a super thin coating with a paintbrush so that the adhering agent touches the bottom of the trackpad and holds the metal trey into place. Then, put it back into its bay, and give it a day to cure, with a very slight weight (I used a paperweight to keep the trackpad depressed) over night.
The next day, it was fantastic. No problems since.
这个答案有帮助吗?
得分 0
添加一条评论
I took the metal shroud out and now the pad sits flush, but my hard click still doesn’t work. Any ideas?
这个答案有帮助吗?
得分 0
添加一条评论
I had a similar fix for this, same to the most voted answer of removing the shroud although I left it in for mine. I just used a few small strips of 2 sided tape, bend the shroud back under and push down on the tape. This works well for me. I also repair cell phones for a living with this tape.
这个答案有帮助吗?
得分 0
添加一条评论
I took the metal sheet off but the track pad isn’t flush because as I was taking the metal sheet off I the track pad slid forward a little and I can’t push it back I do position
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
niyathic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 66
总计 20,817
