跳转到主内容
加入维修社区 - 创建账户
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
Top RAM Slot is not functioning
Hi, I´ve recently bought 2x8gb Ram from OWC following their instructions to order the correct one. tried to install them but when I boot the mac it keeps restarting by itself. I´ve tried both rams separetly, and both working, I´ve finally found that the top ram slot is the one causing problems. The weird thing is that originally I had 4gb and 2gb on the bottom and top ram slots (6GB in total) any idea? any tips?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Try using a lessor stick in the upper slot, leave the 8 GB in.
I use Micromats Atomic to test RAM:
https://www.micromat.com/products/atomic
这个答案有帮助吗?
得分 1
6条评论:
By lessor stick, I means a 4 GB and 2
GB stick.
完成的
Hi @mayer @mayer, thanks for getting back to me so quickly. Could you please rephrase the answer?
Use a lessor stick on the top slot? Sorry not sure what this means.
I can buy atomic software and test the ram, although both ram sticks works on the lower slot…
Many thanks for your help.
完成的
What OS X are you running?
Originally, both the official and actual maximum RAM was 8 GB. However, as confirmed by site sponsor OWC, if running OS X 10.7.5 or higher, updated with the latest EFI, and equipped with proper specification memory modules, this model can support up to 16 GB of RAM.
完成的
@eduhecam What Mayer means by use a lesser stick is to use a RAM stick with less amount of RAM (like let’s say a 4GB or 2 GB instead)
完成的
Thanks @ajcooke01 . I've tried. Worked for 5 mins, 8gb + 4gb at the top (different brands same ram specs) But I've got the spinning wheel, and then completly freeze computer...
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Eduardo Hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 506
