跳转到主内容
How can instal a OS X disc from an external drive
So I have an iMac g3 and I got an external disc drive but every time I try to instal the disc nothing happens. The iMac I have is a 350 mgz model so I have no fire wire. And I don’t know what to do. Any answers would be great.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
what's the matter with the internal drive? What type and brand of external drive did you get?
完成的
The internal drive would just make noise and would try to spit out the disk. The external drive I got is a starcat usb disk drive
完成的
Tell me about the install disk you are trying to use.
完成的
OS X 10.4 tiger
完成的
添加一条评论
1个答案
已选择的解决方案
The maximum operating system on the two iMac G3 350 MHz are :
Apple iMac G3/350 (Slot Loading - Blueberry) Specs
Identifiers: Slot Loading No FW - M7469LL/A - PowerMac2,1 - M5521 -  1821
Pre-Installed MacOS:8.6 Maximum MacOS:X 10.3.9
Apple iMac G3/350 (Summer 2000 - Indigo) Specs
Identifiers: Summer 2000 - No FW/AP - M7667LL/A - PowerMac2,2 - M5521 -  1857
Pre-Installed MacOS:9.0.4 Maximum MacOS:X 10.3.9
So the disk you are trying to install, won’t work on your machine.
Your drive may be working fine but just need the correct system disk.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Carson Howard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 968
