跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for GE Microwave ovens.
Microwave won't heat. Tested or replaced all high volt parts
I’m certainly not an expert, but I am fairly experienced in appliance repair. This one is a head scratcher. Microwave doesn't heat. Diode, cap, transformer, and magnetron all originally tested fine. Current draw right around 10 amps. Out of frustration, I've replaced the all high voltage parts(Cap, diode, trans, and magnetron), Still no heat. Also checked(and double checked) thermal switches, fuses, door switches, wiring, and relay outputs. Anyone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Check the polarity at the wall.
Is the diode in the proper direction?
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Eric Metzger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 164
