跳转到主内容
Lumia 950 XL is a Lumia flagship introduced in 2015.
2 个问题 查看全部
Lumia 950 XL screen issues
Phone Works Fine, Screen doesn't have any damaged, touchscreen works fine.
But I have an issue with my phone, my phone screen blinking to the blank every couple seconds.
When I don't use my phone and it goes to standby mode, the screen goes to the green color, but when I wake up phone screen come backs to normal colors, but screen still blinking every 2 seconds to blank.
But when I do updates or restoring the phone,due that process screen work fine, screen doesnt blink at all and all colors looks fine.Blinking just happens when I use phone.
I tried connect my phone to tv, everything works fine.
So I guess is not hardware issue, but also I dont think it is software issue also, because I tried install different versions of software and it doesnt fixed my issue.
Anybody have an idea what could make this issue?
Any suggestions How can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi!
Have you dropped it or has there been any water damage?
You can try to reflash the firmware of the phone with this tool from Microsoft (it will revert all updates and format the phone and the firmware then install everything anew): https://support.microsoft.com/en-us/help...
这个答案有帮助吗?
得分 1
添加一条评论
Nope I don’t dropped it and its doesn’t have any water damage.
I tried that software, i tried different version of firmware, but problem still exist.
I would think it screen problem, but when I do firmware update, screen never blinking or makes any issue.
It happens just when windows loads and after windows load it happens all the time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
petras18 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 817
