跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Restore successful but boot loop
Hello.
So i get this iPhone 7 on my desk, with water damage, very light corrosion here and there, cleaned and replaced the caps who seemed damaged, now the phone charges normaly (~1A on a 1A charger).
The iPhone turns on and after ~5 second resets itself, so i thought i might be the iOS that is the problem, so i restored with iTunes to latest version, all went well no errors the screen was lit the entire time with the Apple logo and the progress bar. After the restore finished, the iPhone went down and turned back on, but still the boot loop after ~5 seconds.
I repalaced/rebaled the Tristar and Audio IC’s also measured all the relevant main voltages. Also tried to turn on the phone without all the flexes… still boot loop.
Any hints?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Short boot-loop is usually BB related but with a water damaged phone, who knows, it could be anything. did you remove the shields when you did the decontamination?
这个答案有帮助吗?
得分 2
2条评论:
I removed the shields and cleaned everything but no corrosion what so ever. If it where a BB related problem would it not trigger a restore error? I had this kind of a problem before with a iPhone 7 where the problem was a defective/water damaged proxy flex...
完成的
I agree, BB issues should give an error code during restore but when faced with no answers, you have to try something :>).
完成的
添加一条评论
Hello, did you solve problem? I have same issue, little corrosion, bootloop, when i resolder audio with jumper does not help :) yeah and restore without error
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dacian Bujor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 263
