跳转到主内容
The Motorola Moto Z Play (model number XT1635-02, XT1635-01 and XT1635-02) is a droid smartphone that was released in September 2016. The Moto Z Play can be easily distinguished by the word “moto” placed at the top and the square home button placed at the bottom of the front of the phone.
58 个问题 查看全部
Moto Z Play, replaced defective battery, phone no longer charging
The battery on my Moto Z Play expanded and started pushing the screen outwards.
I dis-assembled the phone and replaced the battery, but now the phone does not take a charge.
Tried using the USB cable and wireless charger moto mod, same issue.
Tried a second battery from another supplier, same problem. Not charging.
Tried factory reset, and charging at boot loader, didn’t help.
The phone works off the 20% charge that the replacement batteries came with, works when plugged in with cable.
Is there anything I’m missing? What could be the cause of the problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
did you ever fix this?
im having the same issue
完成的
添加一条评论
1个答案
I am sure it has a charging ic and it sounds like it was damaged from the previous battery. It could have caused a short or it could have damaged the motherboard or possibly knocked parts off or loose from the motherboard. I would take it to a repair shop for an estimate.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
KTP 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 205
