跳转到主内容
The Maytag model LDE8604ACE is a gas dryer produced by Maytag.
Gas dryer will not reheat
I have a maytag ensignia gas dryer. The dryer will heat up initially but will not reheat. The igniter will glow like it does during the initial heat up but no flame on the reheat. The initial heat up will run for 4-6 minutes. The flame will stop. About a minute later the igniter will glow but no flame. I've cleaned the vents but still the same issue. Any thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you find the glow bar igniter glowing red and then fading off without burner ignition, the two solenoid coils on the gas valve are becoming weak and will need to be replaced. Now, if there is restriction in the vent system, the flame will not be drawn back towards the drum and the high limit thermostat will shut off the burner. The igniter will not attempt to come back on until the high limit thermostat cools and resets.
For testing purposes only, disconnect the vent hose from the back of the dryer and then see if the burner cycles off and on properly. If you find the igniter glowing and fading off without burner ignition, replace both solenoid coils on the gas valve. If it appears to be cycling correctly, the vent system is likely restricted.
The coils may test within specifications when cold but when they get hot from the current to open them, they become too weak to open the gas valve.
In order to access the gas solenoid coils, the front panel will have to be taken off.
NOTE: Disconnect the power cord from the power source before servicing.
Thanks go to Joey S
这个答案有帮助吗?
得分 2
2条评论:
Hi @mayer ,
The images aren't there ;-(
完成的
@mayer
I disconnected the vent hose in the back and started the dryer. The dryer igniter turned on and I got flame which continued for about 8 minutes before shutting off. About a minute later the igniter would glow again but no flame. After a couple attempts I shut the dryer off again. It seems to work properly when every thing is cool but not once it heats up.
完成的
添加一条评论
添加你的答案
Burtd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,872
