跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
问题已关闭
water spilled MacBook won't charge. it does see the battery
so water spilled on this computer. it will detect the battery, and magsafe will look like it's charging with the orange light but battery remains at 0% (even though battery could be charged 100%) I have the skill to repair the logic board but I need some help in pinpointing where the issue is. any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you tell me where you found the short and the procedure you used to solve the problem? I have a very similar issue. The battery is recognized and the MagSafe looks as if it's fully charged (green light), but the screen says "Not Charging." Battery is at 0mAh.
完成的
Can you supply a picture of the logic board between the LCD connector and the tester pins? I don't have the logic board anymore but the symptoms you're describing are the same I had.
完成的
添加一条评论
5个答案
已选择的解决方案
Here's where to start. Nobody can really tell you what's happened. Electronics Water Damage
这个答案有帮助吗?
得分 3
1条评论:
thanks but i forgot to mention the procedure has already been done.
完成的
添加一条评论
这个答案有帮助吗?
得分 1
添加一条评论
I managed to repair the board! I scanned it for a bit trying to find burnt IC's or perhaps broken lines until I finally spotted the short. Jumped and computer is back to life. Not bad for $150 :)
这个答案有帮助吗?
得分 0
1条评论:
That's great, glad you got it running.
完成的
添加一条评论
What did you mean Josh when you "Jumped the computer"
这个答案有帮助吗?
得分 0
1条评论:
....and can you upload picts of the repair ?
完成的
添加一条评论
what I mean by jumped (jumpered) the connection - basically replace the broken line by soldering a wire from one area on the logic board to another therefore completing the connection. I need a close up picture to pin point where to jumper since I don't have this logic board anymore.
这个答案有帮助吗?
得分 0
1条评论:
That would not work. It would be like turning on your auto ignition switch and engaging the starter motor and not letting it go.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 1,926
