跳转到主内容
MacBook Air shutting down randomly on OS install
I have a MacBook Air 11” from 2012.
The laptop boots normal but it always shuts down before finishing the installation. Its never the same time it is shutting down, totally random. Sometimes right away a few seconds after booting sometimes 60% in the install.
I dissasambled the laptop and tried it with no peripherals. Same thing still shutting down.
PCB looks very clean und no signs of liquid damage.
I cleaned of the old thermal paste and put new paste on the CPU. Nothing changed.
I am not sure what i am looking for. Is it some kind of power problem that the pmc has a fault or mire likely to be a sensor issue?
Hopefuly some on can help me. I can provid pictures if needed.
Anyone with a similar problem? And probably a Fix?
Thanks a lot peace üt
Update
I found one component missing!
first question what is it, looks weird and not really part of the schematic.
Is that importent and tthe problem?
Looks a little bit like I ripped it of when i took the motherboard out
Update (09/07/2018)
Sierra is working on the Macbook now . It is booting fine and most of the time its all good. but still sometimes it rondomly crashes.
I run the apple service diagnostics tests and it seems to be a Memory Ram issue. Does anyone of you know about Ram issues on the Macbook air 2012? What can i do about it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
What OS X are you trying to install and how are you trying to do it?
完成的
I am trying to install High Sierra
完成的
@niklasjakob - Can you take a second picture showing a bit more of the logic board so I can try to identify the area.
完成的
@Dan i posted another picture
完成的
添加一条评论
2个答案
最有帮助的答案
OK, I’ve ID’d the part you damaged it’s the Hall lid sensor (Green).
The Sensor is a black box in the schematics so I can’t tell you the discreet component (Purple)
hall-sensor.pdf
You’ll need to find a junker to steal the part or just replace the logic board.
这个答案有帮助吗?
得分 4
6条评论:
Does anyone know where i can get this part other than a junker?
完成的
Do you think this could be responseble for the random shut downs?
完成的
The Hall sensor is what puts your system into sleep mode when you close the lid. So when your system is in sleep mode the front White LED will be lit, throbbing on and off. So when your system cuts out is this what you see? If you do then that explains things.
完成的
Do you know where i can find the Partnumber of the hallsensor?
完成的
Sorry guy it's a custom part. You'll need to find a junker logic board to get one or just replace the logic board.
完成的
显示更多的1条评论
添加一条评论
Use an external drive and reformat the blade GUID and try installing just Sierra. Apple has gone to a new format on SSD drives and I have found that it works very poorly on Legacy Machines, which your’s is now.
In case you are not aware, Apple won’t work on any machines (with a couple of excepts) over six years old. They expect you to trash it and go buy a new machine.
Apple to Add 2012 MacBook Air to Vintage List with a New Twist
https://blog.macsales.com/45669-apple-to...
这个答案有帮助吗?
得分 3
1条评论:
i will answer later
完成的
添加一条评论
添加你的答案
Niklas Jakob 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 15
总计 1,723
