跳转到主内容
加入维修社区 - 创建账户
Backlight doesn't work after repair
Display was broken and I’ve removed it. After I took new one and attached it, but the main ribbon (from display board to pcb board) was damaged. I’ve bought new and replace, but now backlight doesn’t work. Service man told, that problem may be in short circuit (when damaged ribbon touched metal tilting mechanism) and backlight is controlled by the BGA 8072PN (upper left corner of photo). But on the forum I’ve read that backlight is controlled by another chip. So I need to repair backlight but don’t know how.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hello, behind the screen, there is a chip management of the screen, in case of indeterminate failure, it is advisable to change the chip, the screen, and the electrical tape, the pieces cost about $ 60.
If the failure is still present, the graphics processor of the motherboard is probably defective.
The repairer must know the reasons for the breakdown before repairing the unit.
这个答案有帮助吗?
得分 0
添加一条评论
Also make sure that the SD card reader submodule is plugged in with its ribbon in its entirety, without skew. The DC-DC converter that powers the LCD's backlight is located on this subassembly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Тарас Аргунов 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 34
总计 700
