跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Low audio on front facing Camera during video record
I have replaced iPhone 6 display. Al works fine, except front facing camera when i record video, audio it si very low, like it’s mute becouse is very hard to hear. It’s strange becouse audio in rear camera work fine during video record, calls, and voice record.
thanks you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This problem is cause by a misalignment of the frontal microphone. On the front earphone grill, inside of the screen, there should be a sticker where the microphone sticks to. There is a hole off to one side (left in this case when the screen is open and in front of you)
On the microphone, there are 2 holes on the ribbon cable. One hole is to align with a plastic pin, and the other hole is on the opposite side and center of the little metal box (microphone) That hole in the center needs to align with the hole in the sticker to let the sound through.
Let me know if that helps! You can notice on my screen that there is a clear plastic over the sticker for the microphone that needs to be removed first for the microphone to stick. Also, do check if your microphone hole is blocked on the ribbon cable form the old sticker or dirt!
Best of luck :) You got this!
这个答案有帮助吗?
得分 2
3条评论:
Are those pictures you took yourself? If so, nice add to your answer!
完成的
@refectio That they are. I just got my new microscope camera a few weeks ago. Its kinda funny though, you can see in my picture that I would probably have a microphone problem too if I just stuck it on there. The hole needs to be another mm to the right or so - so I would stick my tweezers in there and expand it some towards the headphone speaker. I know you probably know that, but thought it might be another nice addition
完成的
You are the best
完成的
添加一条评论
添加你的答案
2mattdell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,878
