跳转到主内容
Repair information for standalone freezers.
193 个问题 查看全部
Can defrosting break your freezer?
I have a zanussi zvc45 freezer, defrosted it in the afternoon, left it open overnight. the next day it tripped the circuit breaker in the house.
*no evidence of flooding as ice that fell off where removed.
*any fluid that might have leaked were absorbed by towel in front of freezer.
Now when I plug it in, it won’t cool despite adjustments to thermostat
thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You may need to let it sit for a week to let it dry out. Sounds like water may have accumulated and is shorting out wires. Why did you need to defrost it? What was going on with it?
UPDATE
Most Frequent Causes for Refrigerator not defrosting
Cause 1
Defrost Control Board
The defrost control board determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Before replacing the defrost control board, first test the defrost heater and defrost thermostat. If the defrost heater and defrost thermostat are working properly, the defrost control board is likely defective.
Cause 2
Defrost Timer
The defrost timer turns on the defrost heater several times throughout the day to melt any frost that may have accumulated on the evaporator coils. If the defrost timer is defective, it may not advance into the defrost cycle, or it may not send power to the defrost heater during the defrost cycle. To determine if the defrost timer is defective, slowly advance the dial into the defrost cycle. The compressor should turn off and the heater should turn on. If the timer does not send power to the defrost components or advance out of the defrost cycle within 30 minutes, this indicates that the defrost timer is not advancing. If the defrost timer is not advancing, replace it.
Cause 3
Defrost Heater Assembly
The defrost heater assembly turns on several times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, the defrost system will not work, and frost will continue to accumulate on the evaporator coils. To determine if the defrost heater is defective, use a multimeter to test it for continuity. If the defrost heater does not have continuity, replace it.
这个答案有帮助吗?
得分 2
2条评论:
Thanks! I'll do just that. I still get electricity in the unit ( as the hazard light is on) but no humming or clicking sound.
完成的
i had to defrost it cause the frost and ice build up was so bad
完成的
添加一条评论
添加你的答案
Dinno Louis Macandog 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 100
