跳转到主内容
加入维修社区 - 创建账户
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
Random touch responses after screen replacement
After replacing display there are many odd random actions occuring. Ie.. I open YouTube and the fifth video on screen starts playing and soon after starts skipping to next video repeatedly. But YouTube music doesn't do this. Telegram messaging randomly switch to different conversations. But Hangouts messaging does not. I couldn't even type this up in the browser because it will repeatedly delete the message but for some reason it's kind of working in Google keep, it's just randomly selecting text making it difficult. It also randomly pasted my clipboard a few times. It seems to be getting worse. After swapping the display it was just the YouTube issue.
  Yes I fallowed the instructions to the T. Made sure to separate the battery connector before unplugging the display. Is it possible my display is faulty or damaged? My iPad is barely usable now
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This sounds like a logic board issue, not a screen issue. What happened to the Pad that you had to replace the display?
这个答案有帮助吗?
得分 2
4条评论:
Dropped it. Screen was cracked. Worked for 5 days before I replaced the screen
完成的
Are you having any issues or symptoms that would lead you to believe the display is at fault? Any artifacts, streaking, partial display?
完成的
No, just the random touch events. Note, I am not touching the screen when it happens.
完成的
I am only assuming it's the display since the iPad was working fine until I replaced the screen.
完成的
添加一条评论
Did you get your screen from iFixit? It should be working 100% perfectly if so, contact iFixit customer support and request a new screen if it’s not working right. If not, there’s a 90% chance it is faulty because getting a new screen elsewhere is a roll of the dice. I suggest you order a new one from iFixit, and watch this guide for installation.
This assembly includes the LCD and glass digitizer screen and the display daughter board and flex cables.图片
产品
iPad Pro 12.9" (2015) Screen
$249.99
这个答案有帮助吗?
得分 1
2条评论:
I did purchase the screen from ifixit. I'll contact customer support, ty
完成的
threethirteeneleven - Big sigh of relief for you, because iFixit customer support works wonders! Have a good rest of your day.
完成的
添加一条评论
添加你的答案
threethirteeneleven 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 174
