跳转到主内容
The Dyson DC58 is manufactured by Dyson. It is an easy to handle, handheld vacuum powered by a V6 motor that provides powerful suction for up to 20 minutes.
10 个问题 查看全部
Why vacuum on and off?
Hold switch to on but the motor goes on and off and on and off etc.. I though that it was filter problem but just replaced with a new filter but still goes on and off and on and off…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Random on-off s indicate possible connection problems. It could be anywhere, such as switch, battery connectors, cable lug or solder connections, or even motor brushes (unlikely if gadget is little used). If you can check these yourself fine; if not have a technician do the check.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dannis Yang 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 94
