跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
276 个问题 查看全部
LCD Display backlight issue, Can be seen by dropping a torch
My 13” MacBook Pro 2017 (with Touch Bar) got display outage suddenly. The backlight wasn't lighting up (the desktop & its icons could faintly be seen with a torchlight). Connecting to an external display did work.
I tried SMC & NVRAM Reset, neither helped! I contacted Apple Support, after some talks they recommended to reinstall macOS. Didn't work either!
My warranty just ran out 1-2months ago.
In this condition whats your recommendation? FYI: my system didn't get dropped or get wet as far as I am concerned.
I then contacted iService (in Bangladesh) Apples’ authorized reseller, but not very good at service. We don't have any Apple Store/genius bar in our country. After some diagnosis, they found out it’s the display & will take 48kBDT(570$+) to replace + Their diagnosis charge.
But the problem is, I can't trust their diagnosis (There are numerous online resources suggests it can be the logic board, or the display or the ribbon cable).
If after spending ~50k+ (600USD) the iService guys tell me that it was logic board that will be a great frustration!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your problem is a ribbon cable connection of the LED backlight circuit. Here’s a photo explaining the connections:
Photo credit: @just1ed www.macplus.sg
If you can you could try cleaning the connection surfaces and reconnect the connector. Using 85% or better isopropyl alcohol on a cotton swab (Q-Tip) wipe the gold contacts.
Here’s the guide you’ll need to follow to pull the bottom cover 2016末期13寸 MacBook Pro 功能键版本的底壳更换 And yes, this is for a different model than yours it’s the same procedure!
If that doesn’t work you’ll need a new display assembly as the cable its self has a tendency to fail. Apple had been getting a lot of cable failures in all of the new 2016 thru 2017 models. Both the 13 & 15” models share the same display design. Sadly, the cabled are mounted permanently to the display and can’t be replaced on their own.
If you can, on one of your travels get to a real Apple Store and let them fix it so you have a proper record of the repair as I do believe Apple will be offering a rebate for people who had the display replaced. You might even try getting then to post a warranty exception as this is so common a failure and then it would be a free repair. Sorry to say the display is that expensive ;-{
Don’t forget the sticking keyboard issue this system also has is currently being covered under an extended warranty program Keyboard Service Program for MacBook and MacBook Pro
这个答案有帮助吗?
得分 1
7条评论:
That q-tip didn't fix my product. So I guess I'll have to replace the display I guess.
完成的
Sorry guy ;-{ Some folks have managed to get it to work.
完成的
Can anyone find a replacement cable that is long enough?
完成的
If you have a 13" model you're in luck! Apple has acknowledged the defect and offers a extended warranty to replace your display 13-inch MacBook Pro Display Backlight Service Program
完成的
@danj Please remove the photo. You have used illegally used my company Mac Plus's photo and cropped away the our company Logo. I have reported you, the 2nd time now to iFixit for moderation.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Ahmad Firoz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 1,445
